Нда, уже и читать не в состоянии.
Процитировать для людей, которые не умеют читать, не проблематично:
Какая-то документация писал(-а):
The SPI Chip Select (/CS) pin enables and disables device operation. When /CS is high the device is deselected and the Serial Data Output (DO) pin are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or status register cycle is in progress. When /CS is brought low the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device.
. Какая-то документация писал(-а): Так достаточно понятно
