может кто прокоментирровать следующую информацию Found 2Mbit BIOS (6.x)! Found
Found Pentium4-BIOS/platform!
1. New CPU Support : -> fixed.
Unlock Hyper-Trhreading Select for all CPUs
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.0%
Adding start.tmp 87.5%
Adding cpucode.bin .. 98.8%
(c)2002-2003 apple_rom, www.ROM.by
BIOS Patcher ver. 4.23.
BIOS-PartName Segm:Offs Compress/Real_Size "Official" name - what`s meanining
454DN101.BIN 5000:0000 0001:3903/0002:0000 "original.tmp" - MAIN part
awardext.rom 407F:0000 0000:8F58/0000:D1A0 "awardext.rom" - ALT part
ACPITBL.BIN 4003:0000 0000:16F3/0000:4116 "ACPITBL.bin" - ACPI table
awardeyt.rom 400E:0000 0000:386F/0000:5590 "awardeyt.rom" - ALT_2 part
aobar.gif 4011:0000 0000:16A4/0000:16A4
095.rom 4086:0000 0000:3711/0000:8000 "PCI.rom" ~ SCSI-BIOS
EN.stf 4029:0000 0000:2F1E/0000:6E30 "_en_code.bin" - engl-txt Setup
rtsrom_m.lom 4087:0000 0000:7C37/0000:D000 "PCI.rom" ~ SCSI-BIOS
modul.tmp 4E00:0000 0000:03E7/0000:0E6E "modul.tmp" - BIOS Patcher file
start.tmp 2DB2:0009 0000:001C/0000:0020
cpucode.bin 4001:0000 0000:4724/0000:4800 "cpucode.bin" - microcodes
CPU_microcodes (CPUID/version/type):
0F27>0033/Sock 0F24>000F/Sock 0F13>0004/Sock 0F12>0028/Sock 0F0A>0012/Sock
0F12>0001/Slot 0F0A>0005/Slot 0F07>0007/Slot 0F00>0001/Slot
запускал под Windows XP SP2
MB AOpen AX45F-DN
BIOS Phoenix / Award 6.00 PG 12/02/2003 256KB
ошибки при работе BIOS Patcher
