вот лог биоспатчера: BIOS Patcher ver. 4.23. Attention! Advanced qualification
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support :for skip this step press "s" or any another key for continue...s
1a.Bus Disconnect Support :for skip this step press "s" or any another key for continue...s
2. XP frequency :for skip this step press "s" or any another key for continue...s
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open :for skip this step press "s" or any another key for continue...s
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 17.7%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
то бишь не обнаруживается проблемы 32Гбайт
Материнка SL-77KV(B) не загружается с WD800JB
