;search for 32g-bug in orig
BK
vyvod msg_3
assume ds, [cs:orig_0]
mov si, 0
mov bp, 0
.next_32g_orig:
cmp si, 0fff0h
jb @F
.not_32g:
jmp .skip_32g_orig
inc si
cmp dword [ds:si], 066207453h ;'push bx'/'je xxxx'
jne .next_32g_orig ;'push eax'
cmp dword [ds:si+36], 0024f8b26h ;'mov cx,es:[bx][00002]'
jne .next_32g_orig
;store 32g-orig
mov bp, si
.skip_32g_orig:
push bp
;open "0d_i13h.tmp" to [cs:orig_1]
open_file name_0d_i13h_tmp, [cs:id_0d_i13h_tmp], msg_open_1_bin
size_file name_0d_i13h_tmp ;result in EAX
mov [cs:length_0d_i13h_tmp], ax
read_file [cs:id_0d_i13h_tmp], [cs:orig_1], 0, [cs:length_0d_i13h_tmp]
pop bp
;search for 32g-bug
assume ds, [cs:orig_1]
mov si, 0
mov di, 0
.next_32g:
cmp si, [cs:length_0d_i13h_tmp] ;0fff0h
jb @F
jmp .skip_32g
inc si
jne .next_32g ;'push eax'
jne .next_32g
cmp bp, 0
je @F
mov di, si
.skip_32g:
;;poka - SKIP!!!! - neskolko vyzovov bl=0d.... ->???
; mov di, 0
;check - found 32g-problem in any area? (orig or i13h)
mov ax, 0
or ax, bp
or ax, di
cmp ax, 0
je .not32g_bug ;0 = not found
;store 32g-sub
mov_bottom_data _AMI32G, length__AMI32G
;current [cs:bottom_data_codes] = enter point for 'jmp'
mov si, _call__AMI32G
assume [cs:si+1], [cs:bottom_data_codes]
cmp bp, 0 ;found in orig?
je .not_32g_in_orig
off_tbl 50h, bp, _call__AMI32G, length__call__AMI32G
.not_32g_in_orig:
cmp di, 0 ;found in int13h?
je .not_32g_in_int13h
mov bp, di
off_tbl_6000_ami 0dh, bp, _call__AMI32G, length__call__AMI32G
.not_32g_in_int13h:
vyvod msg_fixed
jmp .kon_32g
.not32g_bug:
vyvod msg_not_found
.kon_32g:
_AMI32G:
;put on place "push bx" - in new i13h BX not changed -> havn`t to do "push"
;old 13h-bug = 40bytes
;Word (50:49): Capabilities
;Word (61:60): Total number of user addressable sectors
;Words (84:82): Features/command sets supported
;Words (84:82) shall indicate features/command sets supported. If a defined bit is cleared to zero, the indicated
;features/command set is not supported. If bit 14 of word 83 is set to one and bit 15 of word 83 is cleared to
;zero, the contents of words (83:82) contain valid support information. If not, support information is not valid in
;these words. If bit 14 of word 84 is set to one and bit 15 of word 84 is cleared to zero, the contents of word 84
;contains valid support information. If not, support information is not valid in this word.
;If bit 10 of word 83 is set to one, the 48-bit Address feature set is supported.
;Words (87:85): Features/command sets enabled
;If bit 10 of word 86 is set to one, the 48-bit Address feature set is supported.
;Words (103:100): Maximum user LBA for 48-bit Address feature set
jz .skip
push eax
cmp eax, 66059280 ;32Gb = 03EFFC10h
jbe .small
mov byte [es:bx+0Ch], 0FFh ;Heads
cmp eax, 267382800 ;128Gb = 0FEFF010h
jbe .small
mov byte [es:bx+6], 16 ;FFh ;Sectors
mov cx, 65535 ;Cylinders
pop eax
jmp .exit
.small:
mov al, [es:bx+0Ch] ;Heads
mul byte [es:bx+6] ;Sectors
mov cx, ax ;CX=H*S
pop ax ;low count sectors
pop dx ;high count sectors
div cx ;/(H*S)
shr cx, 1 ;(H*S)/2
cmp dx, cx
jb @F
inc ax
mov cx, ax ;=Cylinders
jmp .exit
.skip:
mov cx, [es:bx+2] ;=Cylinders
.exit:
retf
length__AMI32G = $ - _AMI32G
_call__AMI32G:
call 0F000h:3232h
jmp $+35
length__call__AMI32G = $ - _call__AMI32G
