если не в лом попробуйте пропатчить последний бивис от asus a7v600
Патчиться без проблем 8) , лог ниже. Только исправлять там нечего
Вообще-то обычно адрес прошивки указывать надо, я взял эту
Лог
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (4.5x)!
Enter CPU Name: (max - 32, recomended - 8-24 symbols)
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support : not found.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not found.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
UDMA66/100/133 on UDMA33_only_MB patch: not found.
Tweak options addinng:
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 13.5%
Adding start.tmp 87.5%
Adding tweak.tmp 35.9%
Adding cpucode.bin 55.9%
(c)2002-2004 apple_rom, www.ROM.by
(c)2006 Angel07, www.cgi-scripts.info
Лог
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
[/](c)2002-2004 apple_rom, www.ROM.by
