Пропатчил вот это: dlsvr01.asus.com/pub/ASUS/beta/mb/bios/km132.zip
Лог:
BIOS Patcher ver. 6.00.alpha_11. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required! Found 2Mbit AMI BIOS! !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! Found AMD K7-BIOS/platform! Adding all AMD K7-steppings : -> fixed. 4. 32Gb-problem : not found. FID_Enable adding : -> fixed. Adding AMDK7NOW! support : -> fixed. Tweak options addinng: for skip this step press "s" or any another key for continue... Bus Disconnect Support : -> fixed. Display Features adding : -> fixed. !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by (c)2006 Angel07, www.cgi-scripts.info
Эх...хотелось бы LBA48 на эту мамку...кста мамка то ASUS K7M
Лог:
