Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Еще два вопроса для специалистов на примере 300W БП:
1. До какой степени можно нагрузить БП без вентилятора? напр. до 50 W?
БП разные бывают, радиаторы тоже разные бывают,
где то стоит сборка на 30 ампер, а где то два диода по 3 А
сборка чуть теплая на радиатора при рабоет пк, а диоды 3А отпаиваються от платы от температуры ;))
нагрузка по всем каналам будет?,
или чисто по одному?
2. Возможно ли поставить ключи и выпрямители на радиатор снаружы?
длина проводников скажем до 6-8 см. Как будут помехи?
я когда то так ставил, когда не мог найти
родной радиатор ( т.е ставил с другой стороны радиатора, вверх ногами)
помех при работе пк явно не было замечено ( БП повермастер на 230 ват)
"ключи и выпрямители" - на корпус БП хотите поставить? или я неправильно вас понял?
p.s. взять какой БП с мощными радиаторами,
сборки поставить чуть помощнее по каналам ( хотя может это и не нужно),
и наверно 50W вообще полухолодный будет
да и можно просто сделать эксперемент с вашим БП,
отключит винтелятор, и помониторить температуры( если будите пальцами хвааться, аакуратно, т.к на 1 радиаторе может быть высокое напряжение, а на втором радиаторе высокая температура).
Спасибо Алфан100,
моя идея использовать БП для других целях, бесшумная работа очень важна. Експеримент сделаю, но если ктото споделится опытом, можно не делать.
Интересный второй вариант, если поставить радиаторы нужных размеров, чтобы темп была нормальной без вентилятора. Внутри БП очевидно не поместятся, а если поставить рядом - длинные провода не укажут ли воздействие на работу БП? Частота невысокая. Если ктото из колегг пробовал, интересно узнать.
Аватар пользователя UAM
Сами прикиньте, при КПД 70%(обычный двухтактник) в блоке будет выделяться 50вт/70% =15 ватт тепла. Их надо отвести с радиаторов, дросселя и трансформатора на корпус и потом от него в воздух.
Считайте, какая площадь корпуса будет открыта и какую мощность он сможет отдать.
Гугль в помощь по запросу "расчет площади радиатора".
заранее извиняюсь, если спрашиваю глупость.
транзисторы на разных бп аналогичны? т.е. если у меня два не одинаковых бп и на одном из них погорел транзистор, я могу выпаять его с другого бп?
Можешь, но нужно сравнить datasheet-ы.
Напиши, что было и напиши что есть в наличии
Есть инструменты: осцил DSO-5200A, мультиметр Victor VC9805A+, ESR-метр, паяльник Saike 898D, есть доступ к лицензионной PC-3000 for Win и Achi IR-PRO-SC BGA rework station...
вопрос носит чисто гипотетический характер:)
пока сравнивать нечего, но есть куча убитых бп и время от времени приходится ремонтировать, при том что познания в схемотехнике оставляют желать лучшего.
я так понял весь вопрос в мощности, если взять транзисторы с бп 300Вт и пересадить на 250Вт, то все должно быть тип-топ?
спасибо.
- не совсем. Нужно обязательно обратить внимание на тип транзистора. Если по рабоче-крестьянски: открываешь даташит и смотришь на картинку в верхнем правом углу, а потом уже на максимальные характеристики...
Аватар пользователя bkos
Чем заменить SPS E3150? Стоит в Микролаб 360W.
E3150.jpg 51.36 КБ
KSC5027 и все, чем его можно заменить.
Здравствуйте. Я новичок и столкнулся с ремонтом БП.
В дежурке стоял 13003 а под рукой только 13003D как я понял с диодом между К и Э. пойдет ли он туда?
