Я имею доработать мою биозу путем заменять ть procedure" "EPA; включить IOQ уровня 4 для VIA693ЈA (Iwill VD133 -- motherboard шлица PIII/II 1). I'm смотря для другого более лучшего метода, но не путем использование rom ISA, я знаю эту выходку. Огорченно, я не знаю русского, I'm использующ babelfish для этого перевода.
Вы
2Pinczakko
Speak English, plz, Your automatic translation is not uderstandable...
- Ситчик веселенький есть?..
- Приезжайте, обхохочетесь!..
sorry, I thought everyone here is speaking russian
. I've modify my old mainboard BIOS (Iwill VD133 -- PIII/II) which uses via 693A/596B, by replacing the EPA procedure ,and couple of years ago by using ISA rom. This mod is to enable IOQ (In Order Queue Depth) of 4 level and to enable 4 bank DRAM Interleaving (sorry if I'm wrong spelling it
). You can see my article about it geocities.com/mamanzip/. I'm lookign forward a better method, what I've done is basically a "brute force" method. I saw you guys here are more advanced, I need your advice. Thank you
-- Human knowledge belongs to the world --
-- Знания людей принадлежат миру --
Thanks for Your article, I'll read it with big interest...
), then, only if the mobo will start and the logo www.rom.by will appear, flash second...
For BIOS modding try to use current releaze of BIOS_Patcher by apple_rom (English Readme with BPatcher description and manual is in archive folder); in the same folder with Patcher MUST be CBROM (v.2.07 only!!!), LHA and Real_Processor_Codes...
Be careful, plz, pay attention to read about the syntax and keys, and do two versions of BIOS file - with and without "undo" mode; flash first of them first (
If You will need to set "undo" mode, press the "-" button at system start up (works not at all cases) or disconnect the keyboard before the mobo starts (note: the USB-keyboard = "undo"!)...
And one more - if BPatcher will write in log to flash with boot-block - flash only with it; if will write that new FSB meanings founded and fixed - unlock them with Modbin (and don't forget to correct CRC with CBROM - release/add something in BIOS file - after working with Modbin)...
Good luck!
PS: Everyone here speaks Russian, but sometime...
Thank you. I'll learn russian somehow, I'm currently able to speak 5 languages, I hope it shouldn't be a big problem
. Russian speaking countries are more advanced than the english speaking country in things like this. I have to admit so, because this is the fact. Thanks a lot
BTW, is this bios patcher program is open source ? if it is so, where can I download the source code ? Thx
You see, here are some smart guys who don't beleve Intel that "more and more MHz" (and more and more money
And about BPatcher source code You need to talk with apple_rom, IMHO, by private message or mail ...
I agree with you
. I've been crawling over the net for several years to find a community that think the way I also think. Finally after few frustrating years, I found it here, I'll learn russian as fast as I can so that I can help in your development and "research" guys. I like this style of development, I will share all the resources I have to you. I know most of you are more knowledgeable than me, so, pardon me if that disturbs you :oops: . Thx a lot
Good luck once again...
PS: Something for Your profile: the correct name of Your country in Russian is "Индонезия"; and the right translation for Your tagline is: "Знания людей принадлежат миру" (let's begin Your Russian lessons right now
Pardon me
, what do I need to type the cyrillic alphabet which you are using here? I only have USA type keyboard. Do you guys using dvorak keyboard or something else to type it ?
We use special latin/cyrillic keyboards...
There are some free-ware automatic latin/cyrillic transliterators, AFAIC, try to find one...
