28 мая 2004 - 20:27 Unknown BIOS Mr. Q >>8560 >> 158.88
Thanks for Your article, I'll read it with big interest...
For BIOS modding try to use current releaze of BIOS_Patcher by apple_rom (English Readme with BPatcher description and manual is in archive folder); in the same folder with Patcher MUST be CBROM (v.2.07 only!!!), LHA and Real_Processor_Codes...
Be careful, plz, pay attention to read about the syntax and keys, and do two versions of BIOS file - with and without "undo" mode; flash first of them first ( ), then, only if the mobo will start and the logo www.rom.by will appear, flash second...
If You will need to set "undo" mode, press the "-" button at system start up (works not at all cases) or disconnect the keyboard before the mobo starts (note: the USB-keyboard = "undo"!)...
And one more - if BPatcher will write in log to flash with boot-block - flash only with it; if will write that new FSB meanings founded and fixed - unlock them with Modbin (and don't forget to correct CRC with CBROM - release/add something in BIOS file - after working with Modbin)...
Good luck!
Good luck!
PS: Everyone here speaks Russian, but sometime...
