sorry, I thought everyone here is speaking russian . I've modify my old mainboard BIOS (Iwill VD133 -- PIII/II) which uses via 693A/596B, by replacing the EPA procedure ,and couple of years ago by using ISA rom. This mod is to enable IOQ (In Order Queue Depth) of 4 level and to enable 4 bank DRAM Interleaving (sorry if I'm wrong spelling it ). You can see my article about it geocities.com/mamanzip/. I'm lookign forward a better method, what I've done is basically a "brute force" method. I saw you guys here are more advanced, I need your advice. Thank you
