Hidden да тот же nvflash с ключиком
Hidden
да тот же nvflash с ключиком -b
NVIDIA Flash ROM utility v03.15
Example of use: NVFLASH -s4 -fBIOS.ROM -l
 -f  Flash the ROM using , then do compare and ~CRC32.
     Same as -f, but forces confirmation.
 -b  Read ROM and save to .
 -k  Read ROM and compare with .
 -x  Xfer TV data from file to AT29LV512; SST29LE/VE512 SST39VF512.
 -v  Display file version and ~CRC32 (if no filename, acts on ROM).
 -t            Display 256 bytes of ROM, at offset C000h
 -e            Erase the ROM.
 -d            Display 256 bytes of ROM, at offset 0.
 -c            Check for supported EEPROM.
 -l            Don't light keyboard LEDs.
 -p            Don't pause if ROMfile & chip PCI VenID, DevID mismatch.
 -u            Don't pause if ROMfile & chip PCI subsystem ID mismatch.
 -h            Reboot the PC after other tasks completed.
 -w            Write protect ROM (only works on some ROMs).
 -r            Remove ROM Write protect. (only works on some ROMs).
 -a            List all supported device indexes.
 -m            Enable Macintosh (FCode) compatible mode.
 -g  Force a specific device index.
 -i  Force specific device instance (use with -g).
 -?            Display this screen.
 -s#           Silence level:
   default       All progress messages, all beeps.
   #=1           No progress messages, no beeps.
   #=2           No progress messages, no progress beeps.
   #=3           No progress messages.
   #=4           No progress beeps.
   #=5           No beeps.
NVFLASH supports these EEPROMs:
SST   29EE512       64Kx8          5.0V, 128B page,  0k blk, Man,Dev=(BF,5D)
SST   29LE/VE512    64Kx8      2.9,2.7V, 128B page,  0k blk, Man,Dev=(BF,3D)
SST   29EE010      128Kx8          5.0V, 128B page,  0k blk, Man,Dev=(BF,07)
SST   29LE/VE010   128Kx8      2.9,2.7V, 128B page,  0k blk, Man,Dev=(BF,08)
SST   39VF512       64Kx8      2.7-3.6V,   1B page,  4k blk, Man,Dev=(BF,D4)
SST   39VF010      128Kx8      2.7-3.6V,   1B page,  4k blk, Man,Dev=(BF,D5)
SST   39SF010      128Kx8          5.0V,   1B page,  4k blk, Man,Dev=(BF,B5)
Atmel 29C512        64Kx8          5.0V, 128B page,  0k blk, Man,Dev=(1F,5D)
Atmel 29C010A      128Kx8          5.0V, 128B page,  0k blk, Man,Dev=(1F,D5)
Atmel 29LV512       64Kx8          3.0V, 128B page,  0k blk, Man,Dev=(1F,3D)
Atmel 29LV/BV010A  128Kx8          3.0V, 128B page,  0k blk, Man,Dev=(1F,35)
Atmel 49F512        64Kx8  5.0,3.0,2.7V,   1B page,  0k blk, Man,Dev=(1F,03)
Atmel 49F001       128Kx8          5.0V,   1B page,  0k blk, Man,Dev=(1F,05)
Atmel 49F001T      128Kx8          5.0V,   1B page,  0k blk, Man,Dev=(1F,04)
Atmel 49F010       128Kx8          5.0V,   1B page,  0k blk, Man,Dev=(1F,87)
Atmel 49(H)BV/LV01 128Kx8      2.7-3.6V,   1B page,  0k blk, Man,Dev=(1F,17)
AMD   29LV010      128Kx8         2.7vV,   1B page, 16k blk, Man,Dev=(01,6E)
AMD   29LV001T     128Kx8         2.7vV,   1B page, 16k blk, Man,Dev=(01,ED)
AMD   29LV001B     128Kx8         2.7vV,   1B page, 16k blk, Man,Dev=(01,6D)
MX    29F001T      128Kx8          5.0V,   1B page,  0k blk, Man,Dev=(C2,18)
MX    29F001B      128Kx8          5.0V,   1B page,  0k blk, Man,Dev=(C2,19)
ST    M29W512B      64Kx8      2.7-3.6V,   1B page,  0k blk, Man,Dev=(20,27)
WBond W29EE512      64Kx8          5.0V, 128B page,  0k blk, Man,Dev=(DA,C8)
V3800 pro (TNT2)
