icbook Так до этого висело
icbook Так до этого висело "Работает на технике AQ", что будет висеть потом не знаю, но у них последнее время тоже порой движек захлебывается...
Евгений Беспалов Если интересно, вот искомый фрагмент:
<pre id="line64"><
<span class="start-tag">object</span>
<span class="attribute-name"> classid</span>
=<span class="attribute-value">"clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" </span>
<span class="attribute-name">codebase</span>
"http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
#version=5,0,0,0" </span>
<span class="attribute-name">width</span>
=<span class="attribute-value">"230" </span>
<span class="attribute-name">height</span>
=<span class="attribute-value">"30" </span>
<span class="attribute-name">id</span>
=<span class="attribute-value">"etegro" </span>
<span class="attribute-name">align</span>
=<span class="attribute-value">"middle"</span>
><<span class="start-tag">param</span>
<span class="attribute-name"> name</span>
=<span class="attribute-value">"allowScriptAccess" </span>
<span class="attribute-name">value</span>
=<span class="attribute-value">"sameDomain"</span>
=<span class="attribute-value">"movie" </span>
=<span class="attribute-value">"/etegro.swf"</span>
=<span class="attribute-value">"quality" </span>
=<span class="attribute-value">"high"</span>
=<span class="attribute-value">"bgcolor" </span>
=<span class="attribute-value">"#ffffff"</span>
><<span class="start-tag">embed</span>
<span class="attribute-name"> src</span>
=<span class="attribute-value">"/etegro.swf" </span>
<span class="attribute-name">quality</span>
=<span class="attribute-value">"high" </span>
<span class="attribute-name">bgcolor</span>
=<span class="attribute-value">"#ffffff" </span>
<span class="attribute-name">name</span>
=<span class="attribute-value">"middle" </span>
<span class="attribute-name">allowScriptAccess</span>
=<span class="attribute-value">"sameDomain" </span>
<span class="attribute-name">type</span>
=<span class="attribute-value">"application/x-shockwave-flash" </span>
<span class="attribute-name">pluginspage</span>
"http://www.macromedia.com/go/getflashplayer"</span>
></<span class="end-tag">object</span>
Новый сервер 2008
  • Сегодня А теперь данные за 13/12/2007
  • Вообще-то как то странно это видеть при 2-х
  • Я как-то привык к тому, что проставщик просто
  • Как показывает моя практика, второй процессор
  • Как показывает моя практика, второй процессор или ставится
  • Мне кажется, что 2.5 SAS нам неактуальны
  • Главная засада у нынешних Интеловских матерей как
  • Re: POST-138850
  • Судя по "1 x Intel® Adaptive Slot4" -
  • Просто интересно: что есть платформа для
  • Я бы выделил, чуть, чуть денег, на новый
  • парни, если вдруг надумаете сообразить новый сервер таким
  • Лично я исхожу слюнями на этот вариант
  • NUMA совершенно прозрачна для приложений. Но в случае
  • > Либо полноценный аппаратный контроллер Лишь бы он был
  • Говнорейды на ICH и прочих Sil - это
  • Я тоже в первую очередь имел ввиду AQ
  • AMD рассматривать - это правильно, спору
  • Вариант с AMD Opteron был предложен лишь
  • Очень важно: стартовать можно и с Intel ICH7R,
  • 1. 2. Ещё?
  • По выбору: цена, имя, знакомства... CPU
  • Тогда dreamlist: 1) Желательно иметь брэндовую
  • Похоже - убедил. Стоимость референс-дизайн-сервера не приводил специально,
  • Да, просмотрел, это не подойдёт. Я бы предложил
  • Я имел ввиду IBM и Аквариус - т.к.
  • Из чего следует, что предлагается FOB Крыжополь?
  • Я не думаю, что мы потянет перезд на
  • Для сравнения (бюджет << 2K$): Вариант 1: SATA
  • Роман, 1xSATA fixed drive bays
  • IMHO При таком раскладе возможны только
  • Supermicro Superserver 5015C-MF+B - вне дистрибъюции, наличие
  • Возможно не в тему, но... Была идея
  • Да, речь о новом в обоих смыслах. Например,
  • Имеет ли смысл думать о нормальном и новом
