Вот состояние смарта. Victoria 3.52 freeware | (c) 2002-2006
Victoria 3.52 freeware | (c) 2002-2006 Sergei Kazanskij | hdd-911.com
ERR INX CORR DRQ DRSC WRFT DRDY BUSY HPA AMNF T0NF ABRT IDNF UNC BBK 02:00:01
SMART return status: Good MAXTOR STM3250310AS SN: 6RYKGD47
ID Attributs name Val Worst Tresh Raw Flags Graphic
1 Raw read error rate.......100 253 6 0 Pf Pr Er L***********
3 Spin-up time..............97 97 0 0 Pf L **********
4 Number of spin-up times...98 98 20 2367 Pf C S **********
5 Reallocated sector count..100 100 36 2 Pf C S L ***********
7 Seek error rate...........74 60 30 26048185 Pf Pr Er L********
9 Power-on time.............98 98 0 1933 Pf C S **********
10 Spin-up retries...........100 100 97 0 Pf C L ***********
12 Start/stop count..........98 98 20 2411 Pf C S **********
187 unknown attribut..........35 35 0 65 Pf C S ****
189 unknown attribut..........100 100 0 0 Pf Er C S ***********
190 Airflow Temperature.......62 53 45 789512230 Pf S *******
194 HDD Temperature...........38 47 0 38°C Pf S ****
195 Hardware ECC recovered....99 54 0 14681666 Pf Er C **********
197 Current pending sectors...100 100 0 3 Pf C ***********
198 Offline scan UNC sectors..100 100 0 3 C ***********
199 Ultra DMA CRC errors......200 200 0 0 Pf Pr Er C***********
200 Write error rate..........100 253 0 0 ***********
202 DAM errors................100 253 0 0 Pf C S ***********
А вот паспорт
іModel: MAXTOR STM3250310AS; f/w: 4.AAA
іS/N: 6RYKGD47; LBAs: 488395055
іPass size: 238474 Mb; CHS: 16383/16/63/8062 Mb
іReal size: 238475 Mb (отрезано 2113 LBA)
іSMART: Enabled; Errlog, Selftest - present;
іCACHE: 8192 kb; Look-ahead = ON; Write = ON
іSupp: 48bit LBA,DMA(MWDMA2,UDMA6),DLMC,SMS,DCO,FLC,HPA
іCurrent power mode = Active
іMaster PWD revision = 65534
іSecurity: OFF
External PCI ATA/SATA controller
То что выделено это значит винт шаманили? Может из-за этого глюки и надо заводской размер восстановить?
После включения долгo 1-2мин. определятся винт STATA II Maxtor DiamondMax21 250Gb STM3250310AS.
  • До пустим, у нас есть диск, у которого
  • А что говорит процедура посекторного копирования,
  • А что говорит процедура посекторного копирования, желательно с
  • Диск не ударялся. Вечером выключил утром включил и
  • А этот диск точно не ударен ? У
  • То, что выделено - значит только то, что
