Microprocessor
Part number AXDA2500DKV4D
Processor Core Model 10 (Barton)
Manufacturing process 0.13 micron copper process
Package 453-pin organic PGA
1.95" x 1.95" (4.95 cm x 4.95 cm)
Socket Socket A (Socket 462)
Speed (MHz) 2500 (rated) 1833 (real)
Bus frequency (MHz) 166
Clock multiplier 11
Low power features Halt state Stop Grant states Sleep state Probe state
Other features MMX technology SSE 3DNow! Professional
Level 1 cache size 64 KB code 64 KB data
Level 2 cache size Full-speed exclusive on-die 512 KB
Floating Point Unit Integrated
V core (V) 1.65
Min/Max operating temperature (°C) 0 - 85
Typical/Max power dissipation (W) 53.7 / 68.3
Notes on AMD AXDA2500DKV4D:
Bus frequency is 166 MHz. Because the processor uses Double Data Rate bus the effective bus speed is 333 MHz.
Microprocessor
Clock multiplier 11
V core (V) 1.65
ВОТ ТУТ ФОТО
gapo.zive.net/makingpcbyoneself2/master/2500.jpg
но этот камень не мой хотя один в один (за исключением серийника)
понятно, что буква t обычная
