problem: searching for equivalent contact i can find 1)RSMRTS 2)PSON 3)PSIN 4)3.3 VSB not
problem:
1)RSMRTS
2)PSON
3)PSIN
4)3.3 VSB
not
PSOUT or SUBS that go to the ICH8.
I find a scheme of one near like matherboard ICH9.
from 3.3vsb 2 chips of 4-resistance block are connect to the inputs of 83627(scheme i downloaded 3 chip).
the problem is that while in the scheme of the board I found, but also in the faulty P5B SE i have, the PSOUT (67) should be connect to 3.3vsb through one of these resistors, in my fault P5B-VM DO, this does not happen.
example one chip of 4 res connected to 3.3vsb go to 68/69/70/71 not the 67 PSOUT.
i have 2 chip two connected to 3.3vsb so 8 resistor, of 272 = 2700 ohm but PSOUT is not connect and i don't know where find it (SUSB too).
tomorrow I look for a shovel and try to dig.
wbond.jpg 51.51 КБ
