no i don't read it Harghhhhhhhh !
i find olso this cards
The NVIDIA NVS 510 features four compact mini
DisplayPort connectors with a custom built-in
retention mechanism, delivering ultra-high
resolutions up to 3840x2160 @ 60 Hz. It also
supports advanced DisplayPort 1.2 features like
Multi Stream Technology and Stream Cloning1
>>Microsoft Windows 8 (64-bit and 32-bit)
>>Microsoft Windows 7 (64-bit and 32-bit)
>>Microsoft Windows Vista (64-bit and 32-bit)
>>Microsoft Windows XP (64-bit and 32-bit)
>>Linux® - Full OpenGL implementation,
complete with NVIDIA and ARB extensions
(64-bit and 32-bit)
NVS 510 supports up to 2 simultaneous displays in Windowns XP
NVIDIA® CUDA®
Parallel-Processing
Cores
192
Frame Buffer Memory 2 GB DDR3
Memory Interface 128-bit
Memory Bandwidth 28.5 GB/s
Max Power
Consumption
35 W
Graphics Bus PCI Express
2.0 x16
Display Connectors 4x mini
DisplayPort
Form Factor 2.7” H x 6.3” L
Single Slot
Thermal Solution Active
NVIDIA® QUADRO® 410
>>Microsoft Windows 7
(64-bit and 32-bit)
(64-bit and 32-bit)
(64-bit and 32-bit)
>>Linux® - Full OpenGL implementation, complete with NVIDIA and ARB extensions (64-bit and 32-bit
>>30-bit color (10-bit per each red, green, blue channel)
>>Support for any combination of two connected displays
>>DisplayPort 1.2 (up to 3840x2160 @ 60Hz and 2560x1600 @ 120Hz)
CUDA PARALLEL
PROCESSING CORES
>>192
FRAME BUFFER MEMORY
>>512 MB DDR3
MEMORY INTERFACE
>>64-bit
MEMORY BANDWIDTH
>>14 GB/s
DISPLAY CONNECTORS
>>1 single link DVI-I and
1 Display Port
MAX POWER CONSUMPTION
>>38 W
GRAPHICS BUS
>>PCI Express 2.0 x16
FORM FACTOR
>>2.731” H x 6.93” L, Single slot, Low Profile
THERMAL SOLUTION
>>Active
3D VISION / 3D VISION PRO
>>Support via USB
PNY NVIDIA QUADRO K4200
Accelerate your creativity with NVIDIA® Quadro®—the world’s most powerful workstation graphics. Support for multiple 4K displays, large memory capacity, advanced photorealistic rendering and flexible multi-GPU configurations.
SUPPORTED PLATFORMS
Microsoft Windows 8.1 (64-bit and 32-bit)
Linux® - Full OpenGL implementation, complete with NVIDIA and ARB extensions (64-bit and 32-bit))
Support up to four displays when using DisplayPort 1.2 Multi-Stream
Dual DisplayPort 1.2 (supporting resolutions such as 3840x2160 @60 Hz)
Dual-link DVI-I/DVI-D outputs (up to 2560 x1600 @ 60 Hz and 1920x1200 @ 120 Hz)
SYSTEM INTERFACE
PCI Express 2.0 x16
108 W
THERMAL SOLUTION
Ultra-quiet active fansink
FORM FACTOR
111.15 mm (H) x 241.3 mm (L)
Single Slot, Full Height
DISPLAY CONNECTORS
1 x DVI-I DL, 2 x DP1.2, 1 x Stereo1
MAX SIMULTANEOUS DISPLAYS
3 direct, 4 DP 1.2 Multi-Stream
MAX DP 1.2 RESOLUTION
3480 x 2160 @ 60 Hz
Do you know someone that was able to drive 4K in windows XP at 60hz ?
thanks
(64-bit and 32-bit)
NVIDIA® CUDA®
Parallel-Processing
Cores
192
Max Power
Consumption
35 W
2.0 x16
DisplayPort
Single Slot
NVIDIA® QUADRO® 410
>>Microsoft Windows 7
(64-bit and 32-bit)
(64-bit and 32-bit)
(64-bit and 32-bit)
CUDA PARALLEL
PROCESSING CORES
>>192
FRAME BUFFER MEMORY
>>512 MB DDR3
MEMORY INTERFACE
>>64-bit
MEMORY BANDWIDTH
>>14 GB/s
DISPLAY CONNECTORS
1 Display Port
>>38 W
GRAPHICS BUS
>>PCI Express 2.0 x16
FORM FACTOR
THERMAL SOLUTION
>>Active
>>Support via USB
SUPPORTED PLATFORMS
SYSTEM INTERFACE
PCI Express 2.0 x16
108 W
THERMAL SOLUTION
FORM FACTOR
DISPLAY CONNECTORS
3480 x 2160 @ 60 Hz
thanks
