1. Drivers for Win XP. 2. You
23 Сен 2019 - 23:17
Сказочник
27403
1742.14
2. You may have some problems -
example
P5B-VM DO die
No, I don't know :).
no i don't read it Harghhhhhhhh ! i
I gave you link. You didn't
1)i forget, i find the driver for XP
Hi Maco, i'm going crazy ... The old CRT
North bridge capability and memory module
Questions ... 1) both P5B-VM and P5B-VM DO motherboards have
IMHO yes.
so PSU,CPU,DDR2,etc..all is OK stf later писал(-а): but the problem
OK i solved! I made the measurements but it's
It isn't necessary :). PSOUT# may
problem: searching for equivalent contact i can find 1)RSMRTS 2)PSON 3)PSIN 4)3.3 VSB not
I use thin tip probe for
Hummm ... I'm doing it, but it's impossible
Too much talk and not enough useful
Hi Maco, I know what is flash a bios,but
Do you really not see the
Hi, Thanks maco, it's the first time i put
You are wrong. RTC battery isn't
2. You may have some problems - example.
