Это в хумор надо... хинт: На кой
1. New CPU Support :Can`t find/more_found "AuthAMD"!
2. XP frequency :Can`t found frequency!
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not found.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
Это в хумор надо...
хинт: На кой черт вливать биос, в котором ничего не пропатчено....
ВОПРОС ... про мать gigabyte ga-7400sl
