AMIBCP stands for American Megatrends BIOS Configuration Program. It provides you, the OEM or system integrator, with an easy way to customize some of the AMIBIOS features without coding. This means that you do not have to contact American Megatrends every time a minor change has to be made in your system’s AMIBIOS. With AMIBCP, you can customize your AMIBIOS. This can speedup system development and allow you a greater degree of freedom in adding or changing system features.
Вам понадобится AMIBCP v2.43.2
