CHANGING SOUTH BRIDGE IN ECS 865G-M8 REV 1.0
THE MODEL IS 865G-M8 REV:1.0
Poblem is with Southbridge that is completily dead. Shortcuts on all Front and rear panel USB-s."Mother" is not turning on at all, even on force.
My question is about tehnology taking of old one and putting on a new one bridge. (I found a promising one for donor:))
1) What temperature of air from desoldering air pipe tool shoud be when I taking of working bridge from donor and putting it on reciver mobo using method as described in "Замена южных мостов ". I burned some bridges wile trying to solve "отвал", so I whant to be sure that temperature is harmless for bridge it self.
2) When bridge is set down to reciver and soldered, should I check som other things that are need to be changed in every case of this operation?
Eny experience and advices abouth this?
В ветке "технологии" есть соответствующая тема:
rom.by/forum/BGA_-_пайка?page=5
Там вы должны найти ответы на все интересующие вас вопросы.
А вот ссылка на подробное руководство из Wiki:
rom.by/node/16450
Да, и если вы не имеете опыта замены южных мостов возможно следует сначала попробовать восстановить плату таким образом:
rom.by/node/16403
