Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Присоединюсь к вопросу с предыдущей страницы по-поводу D209L, что кроме них могло сгореть? Выпаял их -один почти развалился, второй треснул. Умерли после того, как наши электрики подключили 2 фазы.
Да, дежурка есть, во всяком случае год назад была:)
Модель - FSP ATX-350GTF.
Первичку и обвязку транзисторов прозвоните. Меняются на 13007 или 13009.
Привет.
Вот озадачился вопросом замены ST W20NM50. Стоят в схеме PFC на ML4824IP1. Не могу найти точно такие но есть ST W20NM60FD. Посмотрел дейташиты - различаются R(ds) 0.20 и 0.25 ома соответственно. Насколько это принципиальная разница. Если в процентном отношении то сопротивление второго на 25% больше. Не могу понять насколько критична эта разница.
Аватар пользователя UAM
На 25% будет больше греться.
Думаю, не особо критична.
Помогите подобрать пару транзисторов(npn/pnp) с параметрами Pkmax=1.5:1.8 вт, Ikmax = 1.7A!!!!!!!
Что-то типа КТ816/КТ817, например ?
Аватар пользователя c0der
Извиняюсь, если вопрос тупой, но тем не менее рискну его задать....
Не могли бы вы посоветовать небольшой список хотя бы сновных транзисторов, диодных мостов и ШИМ, которые применяются (или на которые можно заменить) в блоках питания мощностью от 350Вт....
Хочу освоить ремонт блоков питания, а с элементной базой туговато....
На днях буду заказывать радиодетали, и за одно хотелось бы и для блоков питания элементную базу заказать...
Я конечно прекрасно понимаю, что здесь можно найти все элементы, на которых построены блоки питания, но их здесь очень много, и покупать всё это черезвычайно накладно получится....
Так что мне бы основной список..... Чаще мне попадаются БП FSP, Power Man, Microlab....
Заранее спасибо. Надеюсь на понимание....
А я не брезгую чинить 350 и ниже. Поэтому напишу, что у меня идет чаще всего.
В первую очередь, конденсаторы 1000х16 в дежурку.
10х50, 47х50в
2200, 3300 на 10,16 вольт.
TL494, 4N60, 13009, диоды в мосты FR207,FR307, стабилитроны 18в, 6,2в, резисторы 2,2 ом, 100 ом
Куда реже 14-20N60, MBR3045, MBR20100, резисторы 0,1 ом
Аватар пользователя Evlagor
Добавлю свои 5 копеек... Транзисторы маломощные С945, мощный С5027 в дежурку, стабилизатор TL431...
TL431, 2SA733 и 2SC945 проще с трупов наковырять, а вместо KSC5027 дешевле BUT11 ставить. Или на худой конец MJE13007.
