Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Понятненько, большое спасибо!
А вот в горячую часть блока кондеры высоковольтные ставятся. Какой примерно перечень номиналов туда входит?
И мосты выпрямительные, тоже списочек бы примерный....
Про мосты я писал. 4-6-8 ампер не менее чем на 600в. Отдельными диодами набрать дешевле.
Конденсаторы от 470мкф до 1000 мкф на 200 вольт и от 330 до 470 на 400в. Для APFC еще 50 вольт накиньте.
Для ноутов 100-120 мкф на 400-450в. Но надо искать с минимальными размерами. Чаще по высоте, иногда и по диаметру.
Кстати, главный способ заказа деталей: скупаем по 1-2$ нерабочие БП и наковыриваем из них резисторов, полупроводников. А то на тех же высоковольтных конденсаторах разориться можно.
Ну так-то да....
Только не всегда оказывается то что надо, в рабочем состоянии...
После нескольких лет работы скапливается по мешочку биполярников, диодных сборок, высоковольтных кондеров, ящик проводов, ящик плат, пару десятков невыкинутых корпусов. И только конденсаторы, микросхемы и мощные полевики приходится периодически покупать.
Ну сборки обычно приходится менять на более мощные (12А сборка по каналу +12, а то и пару FR302 - несолидно как-то даже для китайца, разве что если его будут ставить на какой-то младший семпрон). Потому - заказать самые ходовые (MBR3045, MBR20100).
По остальному - как уже сказали, диоды (или мосты - от 3А и выше), варисторы (ИМХО - 220..240В, 10-14мм - 14мм обычно везде влазят без особых проблем, потому лучше их), 2N60 (или более мощные - если дешево), BUT11 (можно в пластике), MJE13009, TL494 с десяток или больше, LM339 несколько, LM393 пару, можно пару WT7510 (иногда в китайцах попадаются), пару SG6105 и пару FSDM0365 (для FSP), оптронов с десяток... Ну и конденсаторов ходовых номиналов, покачественнее (из дешевого-доступного - те же Jamicon/Samwha, хотя ессно лучше бы Teapo/Nippon/Epcos - из того что на глаза в рознице попадалось), + SMD керамики 1 мкф или больше (на кондеры в дежурке вешать) - благое дело копеечная вещь, рулона 100шт при цене порядка 2 центов штука хватит надолго. Можно еще керамики 10 мкф - в дежурку вместо электролитов ставить.
Не забыть о низкоомных резисторах - 1, 2.2 Ома 0.25Вт (раскачка) и 2.2, 4.7, 10 Ом 1Вт - дежурка (в цепи истока), + 22 Ом - на +питания TL494.
Насчет высоковольтных кондеров - ИМХО не стоит заморачиваться, с трупиков можно будет наковырять для типовых китайцев. Ну а как понадобится какой-то 400..450В для БП с APFC или ноутбучного - уже по ходу дела покупать.
Для БП с APFC - можно заказать штук 4-5 колечек Т130-52 для дросселей APFC, не помешают.
И ессно предохранителей не забыть (на 5А и 6.3А - самые ходовые).
А вообще - рассчитывать, что 80..90% блоков будут типичными китайцами на TL494 + "супервизор" на рассыпухе или компараторах.
Мне вот в большинстве случаев FSP попадаются, со своими "фирменными" шимами.... Их я слышал, вобще нигде не найти.....
И какие оптроны брать?
И кстати, конденсаторы Hitano нормальные? Лучше Jamicon'а?
Jamicon'ы бывают разных серий с сильно-разными параметрами и ценой, как и емкости большинства других производителей. Конечно всякие Chung и т.п. я не имею в виду.
atxbp.narod.ru/
Ну а в общем?
Просто по Хитано в частности, есть возможность заказывать по выгодным ценам....
