Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Ток, напряжение, сопротивление Rds. Остальное для БП не очень существенно.
Чем из следующих можно заменить FQP 2N60? И кто из них будет полным или отдаленным аналогом?
D30SC4M
MJE13009L
D13007
MBR2045CT
L7805CV
76121P
SBL3040PT
SF1004G
STPR1020CT
F16C20C
C3150
STP2045CT
NDS40-20
C4160
C5027
F12C20C
KIA 7805P
SBL2040CT
STPR1020CT
C3866
STD13007
45N03LT
E13007
J13007
Alexandr027, вы бы хоть какую-то документацию почитали бы на приведенный список, чтоб глупости не спрашивать (у вас в одной куче мосфеты, биполярные, диоды и интегральные стабилизаторы)
Я все перечислил, что есть. А вы не удосужились даже привести хотябы один аналог или сказать что его нет.
D30SC4M
MJE13009L - мощный биполярник в основной
D13007 - биполярник в основной
MBR2045CT - сдвоенный диод Шоттки
L7805CV - стабилизатор 5в
76121P
SBL3040PT - сдвоенный диод Шоттки
SF1004G - Шоттки?
STPR1020CT - сдвоенный диод Шоттки
F16C20C - Шоттки?
C3150
STP2045CT - сдвоенный диод Шоттки
NDS40-20
C4160 - слабенький биполярник в основной
C5027 - биполярный в дежурку
F12C20C
KIA 7805P - стабилизатор 5в
SBL2040CT - сдвоенный диод Шоттки
C3866 - биполярный в дежурку
STD13007 - биполярник в основной
45N03LT - Полевик?
E13007 - биполярник в основной
J13007 - биполярник в основной
полные аналоги от разных производителей:
все с маркировкой 7805
все 13007
Писал по памяти, мог допустить ошибку. Остальные не помню - ищи datasheet
Тот, который ты хочешь заменить - полевой 2А 600В. Можно менять на 4N60 (4А) 6N60 (6А), но они дороже.
Есть инструменты: осцил DSO-5200A, мультиметр Victor VC9805A+, ESR-метр, паяльник Saike 898D, есть доступ к лицензионной PC-3000 for Win и Achi IR-PRO-SC BGA rework station...
Его нет.
Привет!
Не могу найти дата шиит на С5679.
БП DTK, плата Macron Power 300 W.
ШИМ 494, дежурка С5027.
С5679 - ключевые транзисторы (какойто китайский шит)
попробую 13007
Дубли удалил
doomnik
Какой-то левый китаец.FUJIКакая мощность блока, какой ШИМ, где стоит транзистор, в каком корпусе?
Почти наверняка MJE13007- 13009 будет надежнее.
типа вашего БП ( вроде такие же С5679 на PowerMan HPC-300-102 CE )
rom.by/forum/Pomogite_opredelit_defekt_Power_Man_HPC-300-102CE_mozhet
у этого ТС стояли два с4106 на 1 радиатора
с4106 -> аналог 13007\13009 ( только слабее)
Еще два вопроса для специалистов на примере 300W БП:
1. До какой степени можно нагрузить БП без вентилятора? напр. до 50 W?
2. Возможно ли поставить ключи и выпрямители на радиатор снаружы? длина проводников скажем до 6-8 см. Как будут помехи?
