I started with 12.5*133, boot ok (except I was compelled to Reset everytime I start the machine).
I used the "wire trick", to access coefficient > 12.5.
Only the 17x seems stable with the motherboard (which is sufficient to me!), pressing the power button now seems ok to start the machine (no need Ressetting, I have to confirm that however).
But I don't understand why 17x works ??? because my original XP-M 2800+ has a maximum coef of 16x ?????
Thanks
Note: CrystalCPU doesn't start.
Changing the coef with CPUMSR under windows freezes the pc (it was the same with my previous thunderbird 1 Ghz)
IT WORKS !!!!!
Abit KT7a v1.1
Athlon XP-M 2800+@3000+ (2133@2266 MHz, 16*133@17*133 Mhz);
Thanks
