xen :" And Jean, would you suggest that I look for a mobile XP instead? I don't want to be dependant on a windows tool, in any case, as I might be running linux as well." My KT7a works with an Athlon, but I don't think evry KT7a works with that sort of processor. I think there is a bit of "chance" in that test. So if you can find a cheap Sempron, try it ! Good luck
Good luck
