Пропатчил ECS 845PE-A800, Award.
Проверить поддержку гипертрединга пока не на чем, стоит Celeron 1,7 Willamette
Отчет:
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Unlock Hyper-Trhreading for all CPUs
Unlock_HT - step 2
Unlock_HT - step 3
Found Pentium4-BIOS/platform!
1. New CPU Support : -> fixed.
Unlock Hyper-Trhreading Select for all CPUs
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
14.Set "Y" as default on exit: not found.
Tweak options addinng:
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.0%
Adding start.tmp 87.5%
Adding tweak.tmp 36.0%
Adding cpucode.bin 96.3%
(c)2002-2004 apple_rom, www.ROM.by
(c)2006 Angel07, www.cgi-scripts.info
Отчет:
Unlock_HT - step 2
Unlock_HT - step 3
