мне не понятно, каким образом данный сигнал влияет на вывод сообщения о смене процессора
Once the case is opened, the signal will be changed from high to low. Meanwhile, the detection circuit inside the IC latches the signal. As a result, the interrupt status and the real-time status can be read at the registers next time when computer is booted.
