Условия запуска 0. When BIOS EC-firmware
Может, покажете, как именно мульт читает биос
Условия запуска
0. When BIOS & EC-firmware 100% are working
1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope)
2. When ACIN = 3.3V
3. When LID_SW# = 3.3V
4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V
5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT#
6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
Under these conditions EC should give command for start.
Epox 5EDAI код FF
