Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
мда, туплю однакоlol
Аватар пользователя vugluskr
Вместо 2N60 неоднократно ставил IRF830, возвратов не было.
БП Chieftec Ctg-750C, полевой транзистор FMH20N60S1 может кто подскажет аналог ...
подойдут такие или нет IRFP460 , IRFP460A ?
Аватар пользователя NintendoCore666
Помогите пожалуйста найти замену 3n90. Такого же не могу найти.
Думаю заменить на такой imrad.kiev.ua/catalog/mosfet/270861 но не знаю подойдет или нет.
Fuck your god as creator. Kill yourself do us all a favour!
Аватар пользователя UAM
Подойдет.
И этот подойдет
imrad.kiev.ua/catalog/mosfet/593952
и этот
imrad.kiev.ua/catalog/mosfet/208013
Спасибо большое за ответ.
Доброго дня (или ночи) честной компании!
Проблема с БП RAP-350. Транзисторы D4207 (Q01, Q02) - преобразователя вышли из строя - один пробит, второй рассыпался. Перекопал Интернет в поисках параметров на данный элемент с нулевым результатом.
Возможна ли замена на какой ни будь транзистор с оглавления темы.
Спасибо.
Ставьте 13007 - для такого БП в самый раз.
Большое спасибо Ромбовод за оперативность.
Здоровья, материального благополучия и успехов в делах.
С уважением, Сергей.
Принесли на ремонт 2 блока IRP-COM1200 II
с пробитыми транзисторами APFC, диодами BYC15-600 и дохлой мелочёвкой, всё восстановил, но вот с транзисторами возникли проблемы,
не могу найти на них документацию, всё, что находится указывает на IGBT принадлежность, но это 100% обычные полевики и судя по маркировке 30А 600В, но смущают два но:
1. Не всегда в маркировке указан ID (пример STW24N60M2)
2. Ближайший доступный для меня аналог - это SPW35N60C3, но но не зная остальных параметров оригинала устанавливать не решаюсь, да и цену на данные транзисторы нельзя назвать демократичной.
Может кто подскажет, что за транзисторы были установлены в оригинале и на что следует обратить внимание при замене в данном конкретном случае.
ЗЫ. Вроде нашёл, что за транзисторы, похоже на SiHW30N60E
