Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Аватар пользователя Leviafan
Part No. Polarity Pcm(mW) Icm(mA) V CBO(V) Lead Arranging Ref.
2N1132 PNP 600 600 50 EBC 2N1132
2N2222 NPN 625 600 60 EBC MPS2222
2N2907 PNP 625 600 60 EBC MPS2907
2N3904 NPN 350 200 60 EBC 2N3904
2N3906 PNP 625 200 40 EBC 2N3906
2N4401 NPN 625 600 60 EBC 2N4401
2N5401 PNP 350 600 160 EBC 2N5401
2N5551 NPN 350 600 180 EBC 2N5551
A1015 PNP 400 150 50 ECB 2SA1015
A1020 PNP 900 -10 -50 ECB 2SA1020
A2018 PNP 1000 2000 45 EBC
A42 NPN 625 500 300 EBC MPSA42
A44 NPN 625 300 500 EBC MPSA44
A562 PNP 500 500 35 ECB 2SA562
A673 PNP 400 500 35 ECB 2SA673
A708 PNP 800 700 80 EBC 2SA708
A733 PNP 250 150 60 ECB 2SA733
A92 PNP 625 500 300 EBC MPSA92
A94 PNP 625 300 400 EBC MPSA94
BF959 NPN 625 100 30 BEC BF959
C1008 NPN 800 700 80 EBC 2SC1008
C1627 NPN 600 300 80 ECB 2SC1627
C1674 NPN 250 20 30 EBC 2SC1674
C1815 NPN 400 150 60 ECB 2SC1815
C2001 NPN 600 700 30 ECB 2SC2001
C2216 NPN 300 50 50 BEC 2SC2216
C2655 NPN 900 2000 50 ECB 2SC2655
C3279 NPN 750 2000 30 ECB 2SC3279
C380 NPN 300 50 35 ECB 2SC380
C383 NPN 300 50 50 ECB 2SC383
C388A NPN 300 50 30 ECB 2SC388A
C458 NPN 200 100 30 EBC 2SC458
C536 NPN 400 100 55 ECB 2SC536
C5585 NPN 900 1000 15 EBC 2SC5585
C8014 NPN 900 2000 40 EBC
C815 NPN 400 200 60 EBC 2SC815
C945 NPN 250 150 60 ECB 2SC945
D261 NPN 500 500 40 EBC 2SD261
D965 NPN 750 5000 40 ECB 2SD965
KSP13 NPN 625 500 30 EBC MPSA13
M28S NPN 625 850 40 ECB M28S
S8050 NPN 625 500 40 EBC S8050
S8550 PNP 625 500 40 EBC S8550
S9011 NPN 400 30 50 EBC SS9011
S9012 PNP 625 500 40 EBC SS9012
S9013 NPN 625 500 40 EBC SS9013
S9014 NPN 450 100 50 EBC SS9014
S9015 PNP 450 100 50 EBC SS9015
S9016 NPN 400 25 30 EBC SS9016
S9018 NPN 400 50 30 EBC SS9018
SS8050 NPN 1000 1500 40 EBC SS8050
SS8550 PNP 1000 1500 40 EBC SS8550
Добрый день!
Подскажите аналог полевого транзистора IRFP22N60K?
Аватар пользователя Vovik
Добрый день!
Подскажите пожалуйста чем можно заменить (из того что можно достать) IRFB11N50A - (Uds) - 500 B, (Id) - 11 А, Pd - 170w, (Rds) - 0.52 Ом. Подходит ли такой к примеру STP14NK60ZFP (Uds) - 600 B, (Id) - 13,5 А, Pd - 40w, (Rds) - 0.45 Ом. IRF стояли в блочке CWT puh400w
Аватар пользователя UAM
В изолированном корпусе не подходит. Перегреется. Pd - 40w
Досталось на халяву куча ST2310FX, можно ли их использовать на замену KSE13009L/MJE13009, 2SC2625, D209L и подобным. Вроде как в списке присутствует практически аналог 2SC5129, но в блоках питания их не встречал. По напряжению и току подходят, но вот как с остальными параметрами? Понятно, что тип корпуса не располагает, но всё же на замену в to-220 корпусе должны подойти?
А коэффициент усиления?
Вот как раз эти "другие" параметры и смущают, хотя Hfe вроде как критического влияния в данном случае оказывать не должен.
ИМХО, раскачка нужна "мощнее" при прочих равных.
Эксперимент поможет. Хотя, в некоторых магазинах PHE13009 0,2$ стоит. Какой смысл усложнять?
Думаю, вместо 13007 пойдут без проблем. В более мощных БП будут перегреваться.
Ннадцать лет назад, когда не было импорта, в АТ блок пробовали поставить КТ838 (h21э=3). При подаче внешнего питания на TL494 блок начинал работать.
Всем спасибо, провёл эксперимент, поставил в место D209L в FSP ATX-350PNR (пришлось делать отверстия в радиаторе под винт крепления ключей почти на 1см выше оригинальных, т.к если ставить в существующие, то выводы у транзисторов пришлось бы отрезать под корень), блок нормально запустился, сейчас буду тестить на адекватную нагрузку для проверки стабильности работы и нагрева ключей, о результатах отпишусь.
После 40 минут теста полёт нормальный, радиатор с силовыми ключами нагрелся заметно сильнее чем радиатор с диодами, градусов до 45-50 (рука терпит нормально), с установленным БП в корпус думаю будет ещё горячее, как греется с родными транзисторами не проверял, но если не ошибаюсь то обычно диоды разогревают свой радиатор сильнее чем ключи свой, не зря же управление оборотами вентилятора делается в зависимости от температуры именно выходного каскада. Попробую переставить терморезистор на радиатор ключей.
ЗЫ. Тестовый стенд: МБ GA-P31-S3G, проц INTEL dual core e5700, память Samsung 2x2GB PC2-6400, видео NV 9600GT, ж.д WD 160GB IDE. Тестовый пакет - одновременно запущенный бублик и тест стабильности из EVEREST-а
В общем после некоторых издевательств сделал вывод, что данные транзисторы можно устанавливать в блоки мощностью вплоть до 350W, на работе блока (по крайней мере в моей тестовой конфигурации) ни как не сказалось, разве что немного большего нагрева самих ключей по сравнению с оригинальными, но в общем-то для самих ключей не критично, разве что негативно скажется на установленные вблизи радиатора литы, но в целом время покажет :).
