Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Аватар пользователя Leviafan
Похоже на два в одном,
timg.danawa.com/prod_img/500000/927/970/img/970927_2.jpg
ошибочка, это Inwinn Commander 1200W II
anandtech.com/Gallery/Album/1163#1
обзоров вроде нет, только картинки
Если нет никаких хитрых топологий, типа: LLC, active clamp, ZVT, full bridge...
Можно поискать мощные схожие аналоги в
techpowerup.com
hardwaresecrets.com/page/power/all
jonnyguru.com/
Например
techpowerup.com/reviews/OCZ/ZX_1250W/4.html
For APFC three 35N60C3 mosfets
As main switchers we find two 24N60C3
самое дешёвое на aliexpress Free shippin 5PCS enuine SPW35N60C3 35N60C3 35N60 (600V 34.6A) - 1,50 Eu.
techpowerup.com/reviews/Zalman/ZM1000-HP_Plus/4.html
As main switches two 32N50C3 mosfets are used
Free shipping 5PCS/LOT FET 32N50C3 32A500V - 1,46 Eu
юзанные ещё дешевле.... правда... может быть обломинго..
hardwaresecrets.com/article/Tagan-TurboJet-TG1100-U95-1100-W-Power-Supply/403
Обзор 2006 года: Tagan TurboJet TG1100-U95, такое ощущение самый древний из 1000+ ваттников.
Здесь вообще по барабану, влепили старые добрые 20N60C3
hardwaresecrets.com/article/OCZ-ProXStream-1000-W-Power-Supply-Review/491
2008 год. то же самое...
hardwaresecrets.com/article/Thermaltake-Toughpower-1500-W-Power-Supply/594
два в одном, очень похож
Each APFC uses two 20N60C3
Each switching section uses two 20N60C3 in the traditional two-transistor forward configuration
hardwaresecrets.com/article/Topower-TOP-1100P10-Power-Supply-Review/654/2
2008 год, опять два в одном
В APFC используются два полевика 35N60C3
В главных ключах обратно же они же 35N60C3
Из этого можно сделать небольшое заключение:
1. Лепят что под рукой, собственно говоря, так-как данный БП как бы два обычных в одном, то их можно воспринимать как два обычных Epsilon FSP600-80GLN.
2. Как появляется что-то помощнее/попрохладнее лепят помощнее/попрохладнее.
IGBT пока в БП АТХ пока не встречались.
Отмазка.
Это, можно утверждать, до тех пор пока не появляются выше означенные новые топологии.
В последних моделях ставят полевики где в названии напрямую указывается сопротивление Rds. Я так понимаю это является решающим фактором в погоне за платинумом.
Например
hardwaresecrets.com/article/NZXT-HALE90-V2-850-W-Power-Supply-Review/1750/4
В APFC стоит IPB60R190C6
infineon.com/dgdl/IPB60R190C6_2_1.pdf?folderId=db3a30431ff98815012019af55d...
В PWM стоит SPA11N80C3, так как применена топология active clamp то нужны мосфеты с более высоким напряжением, а требование по току можно снизить
infineon.com/dgdl/SPA11N80C3_rev2.91_a.pdf?folderId=db3a3043163797a6011638...
и наоборот, на примере Enermax MAXREVO 1500 W (2013 год) там где применена топология LLC ZVT, full bridge там в качестве главных ключей в мосту ставят более хиленькие главные ключи (MDF18N50). Очевидно LLC сглаживает рывки напряжения, а full bridge уменьшает требование по току.
Причём в APFC чаcтенько наблюдем мосфеты на 500V, например FQA 24N50
techpowerup.com/reviews/Enermax/EMR1500EGT/4.html
правда здесь наоборот
techpowerup.com/reviews/Thermaltake/TPX-1375M/4.html
применена топология LLC + ZVT, full bridge в качестве главных ключей SPW35N60C3
ещё
techpowerup.com/reviews/CoolerMaster/V1200/4.html
26NM60N - довольно перспективные
Не похоже :)
Вроде нашёл, что за транзисторы, похоже на SiHW30N60E
Довольно шустрые и Rds тоже всего 0,125
советовать ничего не буду
Интересует как скажется на работоспособность и надёжность большее чем у оригинала почти в два раза Qg и Ciss у spw35n60c3, или можно не обращать на эти параметры внимание?, просто обычно при подборе аналога их тоже стараюсь учитывать.
думаете на обвязке это как-то отражается? надо посидеть о схемкой FSP550-80GLN на толчке поразмышлять...
ну а так методом научного тыка, только чур я этого не говорил
На обвязке врядли, но время перезарядки то больше чем у оригинала, и как это скажется на работу блока APFC не знаю, и сам решить не могу (не хватает знаний ), вот и задаю такие вопросы.
Так и придётся, если больше ни чего не подскажут.
заказал у китайцев 2SC3451 на пробу, приехали. Маркировка С3451, по факту какие то PNP. Теперь гадаю, что скрывается на самом деле
Согласен. К примеру в блоке, который недавно ремонтил, Zalman ZM700-SV стояли ключи APFC P20NM50FD и основные силовые ключи P25NM50N. Заменил их на 20N65C3 в APFC и 20N60C3 в качестве основных ключей (других не нашел по адекватным ценам). Блок работает, думаю замена адекватная. Или я не прав? Подскажите, а то пока не поздно еще перепаяю :)
сомнительно, есть куча других параметров из-за которых полевик будет жарить как печка, учитывая импульсный характер работы - что к примеру с td(on) trise td(off) tfall ?
P.S> скорее лепят то что доступно под рукой покачественнее
Немного теории
Разработка и применение высокоскоростных схем управления силовыми
полевыми транзисторами.
Аватар пользователя Fantasy22
Можно заменить в дежурке транзистор 2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w на KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
