Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Задам ещё один вопросик, Можно ли заменить транзистор IRFB3306G (стоящие в каскаде формирования 12В в БП IN WIN Commander II 1200W), который у нас не достать, на STP60NF06 или STP65NF06 коих в достатке в ИБП? Смущает ID и IDM оригинала, который в 2-3 раза выше, но это вроде как ток который способен выдержать кристалл, но данная упаковка должна наложить свои ограничения. Так же интересует можно ли предложенные транзисторы поставить совместно с оригинальными (в БП 2 блока по 4 транзистора, два вылетели, хочу в каждый блок поставить по одному на замену и 3 оригинальных)? Просветите пожалуйста.
Нет, нельзя. И дело не в токе, а в Rds(on) - сопротивлении сток-исток в открытом состоянии. У оригинала 3,3-4,2 mOm, у STP60NF06 - 11,5-14mOm. Перегреется и сгорит.
Так вроде как, из за более высокого Rds(on) нагрузка (т.е. протекающий ток) на данный транзистор будет меньше чем на оригинальные или же я ошибаюсь?.
Aleksey_56 Ток потечет такой, какой нужен нагрузке, а из-за более высокого Rds(on) транзистор просто будет сильнее греться. Сопротивление транзистора никак не влияет на ток нагрузки, нагрузке сколько надо столько и возьмет, а вот температура транзистора из-за квадрата тока и большего своего сопротивления будет выше.
Так кто бы спорил :), только протекать ему легче там, где канал "толще", т.е нагрузка на оригинальные транзисторы конечно возрастёт, но и через данный транзистор будет протекать немного меньше тока. Может конечно ошибаюсь, но если проводить аналогии с обычными резисторами включёнными параллельно, то бОльший ток будет протекать через резистор с наимЕньшем сопротивлением. Конечно, применительно к транзисторам в данном случае влияют и другие условия, но это так - мысли вслух.
Aleksey_56 Так если у Вас много транзиторов STP65NF06 и ИБП, так Вы замените все сразу на однотипные и делу конец, разве что придется может охлаждение пересмотреть... вентиль там более оборотистый к примеру...
Скажем так: у вас слишком много транзисторов STP65NF06 и вы хотите от них избавиться.
Какой ток потечет через транзисторы решает микросхема синхронного выпрямителя исходя из Rds(on) оригинальных транзисторов. При этом, если 2 транзистора стоят параллельно, делит на 2.
Mr.Barbara
Так МС может решить только какой общий ток будет протекать, но не по каждому транзистору в отдельности, в данном случае 8 транзисторов, которые набраны в два блока, на выходе имеем две "широких линии" с одной из которых идёт отбор на преобразователи 5В и 3,3В, вот в эту линию и хочу поставить "солянку", тем более блок из "фермы", и кроме 12В на нём ни какие другие не используются.
Добрый вечер! Помогите пожалуйста в поиске параметров транзистора С5679 (правильнее видимо будет 2SC5679), Гугл его находит, а когда пытаюсь открыть параметры, выясняется, что такого транзистора не существует. Ну он же у меня есть живьём я хочу их поставить вместо сгоревших 13009 и перед тем как менять хотел бы посмотреть на что они способны.
ingener55 Можете поставить оригинал с демонтажа, стоят не дорого...
ru.aliexpress.com/item/Free-Shipping-10pcs-lot-2SC5679/32333430316.html
