Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Silent Breeze, ну и зачем ему покупать демонтаж того, что и так имеется?
Действительно зачем? Доноры есть но не оказалось там там 13009. Ещё попутно возникает вопрос, а обвязку транзистора не надо менять при замене на другой транзистор, подходящий по параметрам?
Я вместо 13009 поставил 13007 и прекрасно работает!
Но нужно понимать что мощность у бп при этом снизится.
Здравствуйте. Блок питания Winard 650RWA ШИМа SDC 339 и SDC 7500 плата SXJ2012 V1.2, силовые транзисторы маркировка 3DD3320 не могу найти или чем можно заменить
подскажите пожалуйста.
Поставил J13009 они жужжат. Подключаю HDD вырубается блок. Есть транзисторы 2SC3320 может это они???
3DD3320 - документацию найти не сложно, сравнить с документацией кандидата в аналоги тоже не сложно.
Лучше создавайте тему. Считаю, что J13009 лучшая замена, нежели 2SC3320 и это точно не 3DD3320. Хотя, ИМХО, подойдет и этот. Покопайте объвязку силовых, замените литы в базах
Саша
А лучше BUV48A
Вот и я нарвался на подделку 13009. Привлекла цена, везде по 16-17 грн, а я заказал в Техноглобусе (Запорожье) по 10 грн. Звонятся нормально, на холостых блок работает, при малейшей нагрузке вылетают. Долго не мог понять, пока не подкинул вместо них 13007 из какого-то Кодегена.
На фото слева ST13009 оригинал, с ними проблем никогда не было, справа - подделка MJE13009A. 4 шт ушли в мусор(.
Здравствуйте. Подскажите чем заменить транзистор 22NM60N (GK1,2N V6)
Подойдет 20n60c3 (он даже лучше по параметрам)
