Enable Input and Current Limit State Machine
The enable input circuit at the EN/UV pin consists of a low
impedance source follower output set at 1.2 V. The current
through the source follower is limited to 115 μA. When the
current out of this pin exceeds the threshold current, a low logic
level (disable) is generated at the output of the enable circuit,
until the current out of this pin is reduced to less than the
threshold current. Я высказал свое мнение основываясь на последнем предложении .
Но почему же дежурка начинает работать при снижении напряжения на входном электролите?
