А вот что написала правленная версия 2.37 Preformat.....Fail!
Preformat.....Fail! Error Code = C00, Pre-Format Fail!
==================Error Message==============================
Number of bad block is over defect ratio:
Ch#00, Bank#00, Die#00, BadBlockNum: 13, BadBlockNumRatio(1/1000): 6
Ch#00, Bank#01, Die#00, BadBlockNum: 7, BadBlockNumRatio(1/1000): 3
Ch#00, Bank#02, Die#00, BadBlockNum: 2, BadBlockNumRatio(1/1000): 0
Ch#00, Bank#03, Die#00, BadBlockNum: 1, BadBlockNumRatio(1/1000): 0
Ch#01, Bank#00, Die#00, BadBlockNum: 20, BadBlockNumRatio(1/1000): 9
Ch#01, Bank#01, Die#00, BadBlockNum: 3, BadBlockNumRatio(1/1000): 1
Ch#01, Bank#03, Die#00, BadBlockNum: 10, BadBlockNumRatio(1/1000): 4
Ch#02, Bank#00, Die#00, BadBlockNum: 8, BadBlockNumRatio(1/1000): 3
Ch#02, Bank#01, Die#00, BadBlockNum: 9, BadBlockNumRatio(1/1000): 4
Ch#02, Bank#02, Die#00, BadBlockNum: 3, BadBlockNumRatio(1/1000): 1
Ch#02, Bank#03, Die#00, BadBlockNum: 2, BadBlockNumRatio(1/1000): 0
Ch#03, Bank#00, Die#00, BadBlockNum: 7, BadBlockNumRatio(1/1000): 3
Ch#03, Bank#01, Die#00, BadBlockNum: 3, BadBlockNumRatio(1/1000): 1
Ch#03, Bank#02, Die#00, BadBlockNum: 1, BadBlockNumRatio(1/1000): 0
Ch#03, Bank#03, Die#00, BadBlockNum: 9, BadBlockNumRatio(1/1000): 4
Ch#04, Bank#00, Die#00, BadBlockNum: 3, BadBlockNumRatio(1/1000): 1
Ch#04, Bank#01, Die#00, BadBlockNum: 17, BadBlockNumRatio(1/1000): 8
Ch#04, Bank#02, Die#00, BadBlockNum: 6, BadBlockNumRatio(1/1000): 2
Ch#04, Bank#03, Die#00, BadBlockNum: 14, BadBlockNumRatio(1/1000): 6
Ch#05, Bank#00, Die#00, BadBlockNum: 12, BadBlockNumRatio(1/1000): 5
Ch#05, Bank#01, Die#00, BadBlockNum: 2, BadBlockNumRatio(1/1000): 0
Ch#05, Bank#02, Die#00, BadBlockNum: 8, BadBlockNumRatio(1/1000): 3
Ch#05, Bank#03, Die#00, BadBlockNum: 10, BadBlockNumRatio(1/1000): 4
Ch#06, Bank#00, Die#00, BadBlockNum: 10, BadBlockNumRatio(1/1000): 4
Ch#06, Bank#01, Die#00, BadBlockNum: 7, BadBlockNumRatio(1/1000): 3
Ch#06, Bank#02, Die#00, BadBlockNum: 5, BadBlockNumRatio(1/1000): 2
Ch#06, Bank#03, Die#00, BadBlockNum: 1, BadBlockNumRatio(1/1000): 0
Ch#07, Bank#00, Die#00, BadBlockNum: 8, BadBlockNumRatio(1/1000): 3
Ch#07, Bank#01, Die#00, BadBlockNum: 5, BadBlockNumRatio(1/1000): 2
Ch#07, Bank#02, Die#00, BadBlockNum: 3, BadBlockNumRatio(1/1000): 1
Ch#07, Bank#03, Die#00, BadBlockNum: 2, BadBlockNumRatio(1/1000): 0
Bad CH/CE:
Ch#0, CE#0, BadBlockNum: 13
Ch#1, CE#0, BadBlockNum: 20
Ch#2, CE#0, BadBlockNum: 8
Ch#3, CE#0, BadBlockNum: 7
Ch#4, CE#0, BadBlockNum: 3
Ch#5, CE#0, BadBlockNum: 12
Ch#6, CE#0, BadBlockNum: 10
Ch#7, CE#0, BadBlockNum: 8
Ch#0, CE#1, BadBlockNum: 7
Ch#1, CE#1, BadBlockNum: 3
Ch#2, CE#1, BadBlockNum: 9
Ch#3, CE#1, BadBlockNum: 3
Ch#4, CE#1, BadBlockNum: 17
Ch#5, CE#1, BadBlockNum: 2
Ch#6, CE#1, BadBlockNum: 7
Ch#7, CE#1, BadBlockNum: 5
Ch#0, CE#2, BadBlockNum: 2
Ch#2, CE#2, BadBlockNum: 3
Ch#3, CE#2, BadBlockNum: 1
Ch#4, CE#2, BadBlockNum: 6
Ch#5, CE#2, BadBlockNum: 8
Ch#6, CE#2, BadBlockNum: 5
Ch#7, CE#2, BadBlockNum: 3
Ch#0, CE#3, BadBlockNum: 1
Ch#1, CE#3, BadBlockNum: 10
Ch#2, CE#3, BadBlockNum: 2
Ch#3, CE#3, BadBlockNum: 9
Ch#4, CE#3, BadBlockNum: 14
Ch#5, CE#3, BadBlockNum: 10
Ch#6, CE#3, BadBlockNum: 1
Ch#7, CE#3, BadBlockNum: 2
Press any key to continue...
что-то не могу прикрепить файлы - "Ошибка закачки файла. Невозможно переместить закачанный файл."
выложил правленые экзешники сюда
yadi.sk/d/3e8S_6i8335YhH
yadi.sk/d/Xge99kvx335YhV
jmf616 SSD firmware recovery
  • http://www.nix.ru/autocatalog/ssd_silicon_power/SSD-64-Gb-SATA-II-Silicon-Power-Extreme-E20-SP064GBSSDE20S25-25-MLC_125094.html тип чипов MLC Тип интерфейса асинхронный. 16 микросхем памяти
  • ua1956 Какая физически флеш стоит на
  • в том то и дело , что ни
  • ua1956 Silicon Power E20 64
  • Здравствуйте. Помогите Please.Диск Silicon Power E20 64 Gb
  • Shevalier, большое спасибо за инструкцию, удалось поднять Kingston
  • Все оно определяет и ничего не тупит.
  • Хорошая статья, отличные комменты, СПАСИБО! Но у меня проблема
  • ДОС
  • Шить надо не из под винды ? Грузиться
  • Несколькими постами выше восстанавливал свой точно такой .
  • Мужики прошу помощи. Лежит у меня данный дивайс
  • ZuluDrag 1. Определение диска на горячую в
  • Shevalier, К сожалению ,с DOS не каждый раз определяеться
  • ZuluDrag Похоже никто. Ни в одном
  • Привет всем! Может кто имеет параметры Flash.ini для TC58NVG6D2FTA20
  • У меня так и прописано - DefPercentage=48 ResPercentage=68 С
  • VC Все прошилось ( на правленом
  • Все прошилось ( на правленом exe )
  • VC Нужно скачать 2 архива. 1. 110322 - из него
  • Поправил названия , но родной прошивальщик так и
  • VC В этой версии "имя производителя" не
  • Попробовал родную прошивку - сообщило что это
  • VC SYS_STFF.bin - это и
  • с именем разобрался - спасибо. А вот Transcend SSD
  • VC Попытки подсунуть файлы от другой версии
  • Спасибо , вот что получилось . В ACHI шить
  • Gollen if one day you
  • Подскажите плиз . Есть SSD Kingston SV100S2/32G , при
  • Hi, Sorry to write in english, but i dont
  • g1obus У Вас случайно нет информации
  • Хорошая статья, все по полочкам. У Вас случайно нет
